Correction. The gas sending unit is a single wire circuit using the tank as a ground. Today, I took another resistance reading on the sender using a better ground to the car body and got a reading of 05.8 ohms steady with the tank almost full. Coud this reading indicate the sender is working properly?
I was hoping someone would jump in here with specific Packard Super Eight knowledge, but since no one has, I'll throw a few ideas out there.
31model70Dec 10, 2022There is continuity in the wire from the gauge to the sender.
Good to have that potential problem out of the way.
31model70Dec 10, 2022I have 6.01 Volts going into the gauge but only 2.73 V coming out of the gauge on the wire going to the sending unit in the tank. There is 2.71 V in the wire at the sending unit when it is connected to the gauge so it appears the wiring is OK. Is 6 V into the fuel gauge and only 2.7 V out normal?
I don't know, but on most gas gauge systems the voltage on the wire to the tank isn't something you would know or care about.
31model70Dec 10, 2022The unit is marked AO, made in US, Model C.
If that turns out to really be AC, it will work on the same principle as a GM gas gauge, and I have a lot more ideas.
31model70Dec 10, 2022If it is determined I have a bad gauge, I would be content with installing an after market fuel gauge but do not know the resistance rating of the sending unit in order to order a compatible gauge.
That is going to have to come from a service manual, or from someone who just knows. If it happens to use the same resistance range as some common GM, Ford, or Mopar gauge, or an aftermarket standard like Stewart Warner or VDO, then maybe. Even then it would most likely be a 12 volt gauge. I would bet against this happening to work out on a Packard, but until you know what the resistance is, it's hard to tell.
Most electric gauges will swing all the way one way or the other with the wire to the sender disconnected. For instance an AC (General Motors) gauge swings high with the wire disconnected, and low with the wire grounded. The range on those is 0-30 ohms at the sender, 0 being empty and 30 being full. Some other brands of gauge may go the other way. Some types might not use 0 as an end point. Using 0 as an endpoint was in my opinion a really bad idea.
With the key on and the Guage pegging to full, that is reading as an open wire from the Guage to the sending unit. Also, be sure the tank and sender has a good ground. We make a ground harness for all our cars because the tank straps and lower frame are often dirty/rusty.
Bloo & edinmass,
Thanks for your input on my gas gauge problem.
Looking at the sending unit cover, it is worn, rusty and hard to read, meaning it could very well be AC instead of the AO I originally thought.
Per the suggestion, I installed a temporary ground wire from the body of the sending unit to a clean and rust-free body bolt and things changed. With the ignition off, the gas needle sits a little below the empty line. After turning on the key, it now jumps to directly even with the empty line and wiggles a little before stopping there. This is with an almost full tank of gas. When switching to the oil level mode, the needle now moves quickly to the full line rather than the immediate pegging to full it was doing before. Does this mean the gauge is working properly and the problem is with the sending unit? How do I test to be sure?
Even with the separate tank ground wire, I now can't get any resistance readings on the sending unit. I think the readings I got before were probably false because of the lack of a proper ground to the tank.
If it is felt the gauge is OK, should I remove the sender and bench test it at this point? With the holidays coming up and the car needed for a family wedding the first week in January, I am hesitant to fool with the sender if it needs to be repaired, at least until the second week of January. Is there anything I should be doing in the meantime?
Any thoughts on this?
Glen
With the holidays, I didn't have much time to work on this problem. However, the gas gauge is now working properly. When I removed the sending unit from the tank, I noticed a blackened stripe on the bottom of the cork float which indicated the float had been stuck to the bottom of the gas tank. Since the car was stored for some four years before I bought it, I think the gas in the tank evaporated and the cork stuck to the bottom.
I replaced the float with a plastic one from Summit Racing and the gauge is now working as it should. This info may be valuable to those with similar gauge problems with cars that have been stored for extended periods.
Thanks to those who responded.
Glen
