You are probably better off with the car with the dents in it, than the one that has the filler. Even though you may not be able to completely remove the dents without using filler, you will be able to get the dents smooth enough so you don't need lots of filler. A thin application is usually a pretty good fix, but if it's applied too thick, it will eventually crack. At least by starting out looking at the dent, you'll know that your new bondo job will stick to the metal. When it comes to body filler, less is more...
