Well, I would think you should take it to a professional if you want professional results. Assuming the car is running I would trapse it around to various shops in your area paying attention to these things along the way:
How many other old cars are in the shop.
How receptive is the owner to working on your car (meaning are you going to get "financially penalized" for have an old car)
How many cans of bondo are lying around the shop
How clean is the shop
How many cars are in their "lot"-the higher the number the longer your car may lanquish there
How clean are the workers outfits
How quickly can they get to it, (if its right away not a good sign) how long do they say it will take to do it.
Are they willing to do what you want done or do they want to talk you into a complete restoration
Among other logical things like how long have they been in biz, do they have references from other old car guys, hows there BBB rating etc.
Of course get bids from those shops that pass these tests and see where you end up.
Another good place to get recommedations of good body shops (very hard to find in my area) is local Cruis-in car shows.
Top flite work is very expensive. But good work can be had reasonably.
If you want to do it yourself you may want to find someone with a brake or other metal working gear to properly bend the metal into the proper shape, so that lots of bondo isnt required. Bondo isnt an absolute no-no, but should only be used to correct minor surface variations versus constructing things.
Hope this helps
Shawn
Good luck finding a shop willing to give you a price to do the repair you described. Difficult and time consuming. Find someone you trust and pay him for the actual time to do the job then next time you need help he won't turn you away. I would bite the bullet and take it to a resto shop. Modern body shops these days usually have very little experience fabricating and welding. I've done the same repair (different cars) many times. Not fun.
thanks for the replies and tips on finding a shop.
taking it to a shop seems to be the consensus over at the Buick forum also. i guess i'll dig even deeper into my pockets...
